overheating
whipsey
Sun Sep 16, 2007 8:46 pm
i've just had my car running for ten minutes on idle and the temp gauge shot right up the top hose is full of hot water but the bottom hose feels empty would this be the thermostat or the waterpump?
SPADGE
Sun Sep 16, 2007 8:48 pm
If the bottom hose is cold and feels empty then almost certainly the thermostat stuck shut based on the current info.
whipsey
Sun Sep 16, 2007 8:52 pm
i only need to mot it before i swap the engine etc
gazza
Sun Sep 16, 2007 10:37 pm
but they will run it for the emissions bit of the test and if it overheats they will cancel the test and more than likely still charge you
austin360
Mon Sep 17, 2007 6:14 pm
take the stat out and cut the guts outta it it will do to get threw test keep things free flowing :eek:
r4j666
Tue Sep 18, 2007 12:40 pm
i had the same problem m8 and i called the recovery he put lots of water in the car n took the air lock out bleeding or watever it is and now its stays on the half mark b 4 it would go on the red and overheat hope this helps
whipsey
Tue Sep 18, 2007 2:55 pm
how do you bleed the m40?
BD76
Tue Sep 18, 2007 3:14 pm
with great patience
whipsey
Tue Sep 18, 2007 4:12 pm
BD76 wrote:with great patience
that helps
r4j666
Tue Sep 18, 2007 4:22 pm
i did ask the recovery guy he told me to fill it up with water while the car is runing n wen the temp goes on half just squeez the pipes n make sure theres no air lock and the car goes warm from inside to make sure ur therostat is opening and its not stuck etc. i dont no how do to it myself this is wot he told me i would rather take it to my local mechanic and get it dun. hope this helps :?
r4j666
Tue Sep 18, 2007 4:23 pm
mind the spelling mistakes lol :mad:
whipsey
Tue Sep 18, 2007 6:25 pm
will give it a try this week i need to get another battery first though lol
Bailey
Tue Sep 18, 2007 6:40 pm
i had a very similar problem with my m20, the top pipe off the thermostat housing was red hot, bottom one pipe off the rad was cold.
I removed the stat, which didnt really do much, replaced the water pump, which again didnt really acheive much and it turned out to be the viscous fan not working. I had recently rebuilt the engine, and the mistake i made was leaving the viscous fan layed face down, and apparently it knackers them because the oil leaks out of them or something...
Does the car over heat when your driving it along, or just when you stop, when the fans most required?
whipsey
Tue Sep 18, 2007 6:41 pm
just when idleing i think it's been off the road for a while
Bailey
Tue Sep 18, 2007 7:13 pm
the fan should literally increase in speed when the temperature increases, with mine it just span at a reletivly slow speed and didnt change, hence overheating.
n e way, hope it helps. Guy.
you might be better off putting this question in the technical bit mind!!
whipsey
Tue Sep 18, 2007 7:14 pm
might be an idea any mods wanna move it for me winkeye
r4j666
Tue Sep 18, 2007 7:41 pm
gud luk mate hope u sort it, bleeding and taking the air lock out did it for me :wink:
gra325i
Tue Sep 18, 2007 10:00 pm
take the cap of the radiator, take the top hose off the radiator loosen the end attached to the thermostat housing and turn the hose so the radiator end is pointing upwards..now fill SLOWLY with anti freeze/water mixed 50/50 until it starts to pour from the top of the radiator..refit hose and radiator cap...now run car till up to operating temp (usually just under half) turn heater controls to full heat and fan stage 2..going back to the radiator, beside the cap you will see a large plastic crosshead screw open this carefully to about half open, (i use a 50p on the screw as its a perfect fit) now rev the engine to around 2000rpm and watch for running water thru the screw you will know its bled if you have roasting heaters in the cabin and there are no bubbles coming thru the screw
HTH :thumb:
