Compression Ratios
ShakeyC
Post Fri Aug 10, 2007 7:44 pm
Having a thick day today cannot get my head round what it is :mad: help :o:
maxfield
Post Fri Aug 10, 2007 7:48 pm
Look here:
http://www.carbibles.com/fuel_engine_bible_pg2.html
Should explain what it is.
Post Fri Aug 10, 2007 7:52 pm
its the ratio of the volume of when the piston is at bdc : tdc
ie 100ml @bdc - 10ml @tdc = 10:1 compression ratio
ShakeyC
Post Fri Aug 10, 2007 8:17 pm
Ah get it now, what baffles me when people talk about going low ratio for turbo engines and people going higher for turboless ones so why does 1 go down and other up?
Post Fri Aug 10, 2007 8:38 pm
higher compression ratio is more efficient but leads to higher combustion temps and internal pressure therefore when you factor a turbo into the equation it all goes higher again (dynamic ratio i believe) leading to bits not being upto the task ie head gasket and failure occuring, or pre detonation due to the high temps.. hope that makes sense..
Turbo-Brown
Boost Junkie
Post Fri Aug 10, 2007 11:42 pm
Indeed, so 100ml at BDC and 10ml at TDC would mean a clearance of 10ml and a swept volume of 90ml.
So out CR would be (Swept + clearance)/clearance=CR
Giving 90+10=100
And 100/10=10, that being the compression ratio.
That's the static compression ratio, but things like cam timing and lobe profiles, bore:stroke ratios etc will also have their part to play in the compression ratio which the engine actually sees while it's running.
ShakeyC
Post Sun Aug 12, 2007 7:49 pm
Thank you everyone i been learned lol
CHRISP
Boost Junkie
Post Sun Aug 12, 2007 9:49 pm
maxfield wrote:Look here:
Good reading mate :D
318 turbo cab mint for sale offersImage
