Compression Ratios
ShakeyC
Having a thick day today cannot get my head round what it is
help
maxfield
- Homo Hair
its the ratio of the volume of when the piston is at bdc : tdc
ie 100ml @bdc - 10ml @tdc = 10:1 compression ratio
ShakeyC
Ah get it now, what baffles me when people talk about going low ratio for turbo engines and people going higher for turboless ones so why does 1 go down and other up?
- Homo Hair
higher compression ratio is more efficient but leads to higher combustion temps and internal pressure therefore when you factor a turbo into the equation it all goes higher again (dynamic ratio i believe) leading to bits not being upto the task ie head gasket and failure occuring, or pre detonation due to the high temps.. hope that makes sense..
Turbo-Brown
- Boost Junkie
Indeed, so 100ml at BDC and 10ml at TDC would mean a clearance of 10ml and a swept volume of 90ml.
So out CR would be (Swept + clearance)/clearance=CR
Giving 90+10=100
And 100/10=10, that being the compression ratio.
That's the static compression ratio, but things like cam timing and lobe profiles, bore:stroke ratios etc will also have their part to play in the compression ratio which the engine actually sees while it's running.
Giving 90+10=100
ShakeyC
Thank you everyone i been learned lol
CHRISP
- Boost Junkie
Good reading matemaxfield wrote:Look here:
http://www.carbibles.com/fuel_engine_bible_pg2.html
Should explain what it is.
