USB to serial adapters
BadDave
Post Thu Aug 09, 2007 9:47 pm
Hi guys
Sorry if this is in the wrong section
Can any of you guys using standalone management systems recommend a usb to serial adapter as my laptop only has usb ports
And
Can you tell me which ones you've had problems with.
Thanks in advance
Dave
Post Fri Aug 10, 2007 12:46 am
Not an exact parallel, but I know that LPG installers tend to seek out older laptops to use, as the adapters don't seem to work.
Laptop I use for LPG doesn't have USB ports (or even a CD drive) and cost me £15!
m-dtech
Unapproved Trader caution
Post Fri Aug 10, 2007 1:15 am
http://cgi.ebay.co.uk/USB-to-SERIAL-Ada ... dZViewItem
generaly they all work, just depends if you get the correct drivers.
HairyScreech
Post Fri Aug 10, 2007 2:01 pm
have heard of people having dificulties with them and megasquirt.
chu346
Post Fri Aug 10, 2007 3:48 pm
I had problems trying to get one to work with MS.............
Just needed to fiddle with the options although it took a while. I think I had to turn off the buffering.
12345kevin
Post Fri Aug 10, 2007 4:13 pm
It's going to depend on how the megasquirt software has been written, if it's using windows to manage the com ports then all should be fine. If it's accessing the com ports directly then u're probably going to have problems ! Only way is to try it.
FlappySocks
Post Fri Aug 10, 2007 4:18 pm
No problems with MS. The only thing I found, was that you always have to use the same USB port each time, otherwise windows assigns a different com port for the adapter.
BadDave
Post Fri Aug 10, 2007 7:30 pm
HairyScreech wrote:have heard of people having dificulties with them and megasquirt.
Should mention that I'm NOT using Megasquirt. :eek: 8O
Actually going to be using a DTA system
Cheers for your input guys
Dave
BadDave
Post Fri Aug 10, 2007 7:34 pm
Brianmoooore wrote:Not an exact parallel, but I know that LPG installers tend to seek out older laptops to use, as the adapters don't seem to work.
Something for me to consider Brian
Thanks :thumb:
If I can find one cheap enough then it would be a viable option
BadDave
Post Fri Aug 10, 2007 7:37 pm
m-dtech wrote:http://cgi.ebay.co.uk/USB-to-SERIAL-Ada ... dZViewItem
Kikey
:cheers: for the link
Had seen and considered it
Thought I'd wait till I heard the opinions from you guys on here before buying
Dave
Ant
Retired Team Member
Retired Team Member
Post Fri Aug 10, 2007 8:26 pm
there's one issue with te USB to DB9 conversion.
the read/write speed to the ECU can be affected quite badly, and can result in some table corruption as odd bytes are missed out.
Serial is best, I use a dock to get two proper comms ports, allows you to log on one and tweak on the other too, bonus. I've ordered a comms card with twin DB9 for my laptop, fed up with the dock, its bulky and squeaks lol !
DTA is great in most versions dude, software a little overcomplicated IMHO though.
BadDave
Post Fri Aug 10, 2007 8:36 pm
Ant
Cheers for the input
Where are you getting the comms card?
Depending on cost,might be interested in going that route.
BTW
Its the "old" E48 EXP ecu with the latest software from the DTA website
:offtopic:
Bit cheeky asking
BUT
Don't suppose you'd have a suitable base map by any chance??
For a std facelift 325 engine on a set of Suzuki throttle bodies(for now,prior to theT4 being fited) :eek:
I only ask as the ecu is from a rally car with a map for a 4 cylinder.
Dave
Ant
Retired Team Member
Retired Team Member
Post Fri Aug 10, 2007 8:46 pm
Dave, the Comms card is a Toshiba unit, there are belkins available to suit vaious Lappys, have a look on Dabs or similar dude, what model laptop are you using ?
my old tosh satellite EX ( 1990 spec) was plenty good enough, although the screen was poor in low sun conditions, had serial on the motherboard too.
Reminds me, my old VAIO has a serial port hidden under a flap on the back, about the only good thing about the POS
Re the DTAwin map, I'll have a look, TBH not used it for a while, too many other toys :D
BadDave
Post Fri Aug 10, 2007 8:56 pm
Ant wrote:Dave, the Comms card is a Toshiba unit, there are belkins available to suit vaious Lappys, have a look on Dabs or similar dude, what model laptop are you using ?
Laptop is a Compaq Presario V6000 series
AMD Turion 64x2 dual core processors/1 gig ram/multi layewr dvd re writer etc etc.
Will have a look on Dabs/Amazon etc
IF you can find a DTA map,that would be great
ANY 6 pot map would be a start(even 1 for a std motor),can add the throttle bodies in the future if needs be.
Just need to get it fitted and running(with a small mod to the loom)
P.S.
Will probably be emailing you soon RE some Turbo parts
Dave
appletree
Post Sat Aug 11, 2007 7:34 am
If you still havent found a Usb adaptor that works emerald do one that works. when i bought my emerald they suggested i use a special kind of adaptor that uses a certain chip as they had a lot of trouble with people using any old adaptor.
the one they sell is £14 iirc and they post them out next day if its any use to you. :D
BadDave
Post Sun Aug 12, 2007 12:31 am
appletree wrote:If you still havent found a Usb adaptor that works emerald do one that works. when i bought my emerald they suggested i use a special kind of adaptor that uses a certain chip as they had a lot of trouble with people using any old adaptor.
Thanks for that
Will keep it in mind
Found one that fits in the PCMCIA slot and its pretty cheap too
Will try thst 1st
If it doesn't work,then I'll give Emerald a phone
Ant
Retired Team Member
Retired Team Member
Post Mon Oct 22, 2007 7:37 pm
Old thread but an update none the less.....
Serial to USB adapter that works....
PC world, purchase the "newlink" unit, cat number ZP43 USB to D9 male.
I've yet to have an issue with this, tested on 5 brands of standalone ECU ( MS,VEMS, OMEX, DTA and Emerald )
Was under a tenner too, worth a sniff.
BadDave
Post Mon Oct 22, 2007 10:19 pm
Cheers Ant
Found one as well
Seems to work ok on the DTA
It's unbranded (off Ebay)
Comes up as Motorola when it's plugged in though
P.S
I don't suppose you managed to come accross a usable base map for a DTA?
For a M20B25 std except for a set of 38mm thottle bodies???
