Replacing Engine oil 1.8IS M42 ENGINE
no1_jazz
Thu Aug 02, 2007 5:13 pm
Easy Guy's,
as the subject states how do i take the oil out of my 31.8is m42 engine as the one in there has been in there for some time now and its time for it to gte changed.
if anyone has a photo image that will be a gr8 help
Many Thanks
Jazz
maxfield
Thu Aug 02, 2007 5:16 pm
There will be a bung on the sump, undo that with a bowl underneath for it to run in to, you will probably need the car jacked up. Make sure the car engine is cool or you might burn your hands.
sportscarfan
Don't even need to jack it up: if you lie on the ground, and look under the front bumper/spoiler, you will see a hex bolt on the front of the sump, simply undo that, put something underneath to collect the oil, and out it comes. Also change the filter, which is very easy, as it's an element filter, so you only need to change the element.
p.s.: I recommend you run the engine for a little while so that the oil moves around and collects all the dirt laying around, but like said, watch out not to burn yourself. Just a few minutes really. And let it drain for quite a while if you can.
M16
Thu Aug 02, 2007 5:18 pm
maxfield wrote:There will be a bung on the sump, undo that with a bowl underneath for it to run in to, you will probably need the car jacked up. Make sure the car engine is cool or you might burn your hands.
Hot oil drains better and more thoroughly tho.
maxfield
Thu Aug 02, 2007 5:21 pm
Yes it might due because it's thinner but wouldn't be too good if you burnt your hand...
M16
Thu Aug 02, 2007 5:27 pm
It does. But your'e supposed to wear gloves and not actually be anywhere near the oil when it drains.
Chris-W
Thu Aug 02, 2007 6:11 pm
Drain oil with the engine warm. Burning your hand is probably nature's way of telling you to go to a garage.
Jon_Bmw
Dangerous when thinking
Thu Aug 02, 2007 6:18 pm
maxfield wrote: you will probably need the car jacked up. Make sure the car engine is cool or you might burn your hands.
:mad:
Do the reverse of this and all will be well :)
no1_jazz
Thu Aug 02, 2007 7:01 pm
Thnaks alot Guys really appreciate it
Thanks u
Jazz :cool:
dodgem
Fri Aug 03, 2007 1:24 am
:mad:
:lol:
so true.... if you jack the car up it won't drain properly as the bung is the lowest point when the car is level, and warm oil flows more easily than cold oil :D
The Coppers wrote:'Mr Munky... it looks like your suspension is broken... or that you dont have any'
choppa7
Fri Aug 03, 2007 8:58 am
dodgem wrote:
:mad:
:lol:
Depends where you put the jack :wink:
on my 316 m10 I jacked the car up on the opposite side to the drain plug so it was angled towards the ground.
Be careful not to drop the drain plug into the bucket of oil which will be sat there, it gets messy trying to fish around in dirty oil for it, especially the 3rd time :cry:
1990 318i Lux
no1_jazz
Fri Aug 03, 2007 11:29 am
Ill make sure i wont drop the drain plug.
thanks alot guys appreciate it
cheers Jazz :cool:
SDM
Formerly WhiteM3
Sat Aug 04, 2007 5:49 pm
change the oil filter too, which i am about to do, but its in a silly place.
tezk
Sat Aug 04, 2007 6:08 pm
You're supposed to wear gloves as used engine oil is highly toxic and carcinogenic. I can never find mine :roll:
And don't forget not to chuck the used stuff down the drain. I bottle mine up and take it to the recycling centre down the road.
no1_jazz
Sat Aug 04, 2007 9:24 pm
alll done and dusted guys appreciate your help thanks alot just help me on my other post on page 2 named "BIG PROBLEMS WITH TRACKING AND DRIVE SHAFT HELP PLEASE :( !!!!!!"
CHEERS Jazz
