starting a e36 m3 without keys
nickalauski
hi, i've just brought a written off m3 for a s50 / e30 engine conversion. the trouble is i didn't recieve keys!!
with the ignition switch remove i can power up the second position but when turn to crack nothing happens. does anyone know an easy way to start the enigne?
I would like to hear the engine run before i take it out. The car is a 1995 non evo thanks.
whipsey
possibly get a new key from dealers?
HairyScreech
thats an imobiliser kicking in a start inhibit relay. find the relay and go backwards from there.
Steve-E30
- East Sussex Hooligan
Arent the keys chipped for the ecu hence it wont turn over so its to do with the immobiliser , Heard that somewhere
Giggety Giggety Goo!!!
whipsey
thats what i was thinking my vectra lost a small piece of plastic from inside the key turned out to be the imobiliser codeSteve-E30 wrote:Arent the keys chipped for the ecu hence it wont turn over so its to do with the immobiliser , Heard that somewhere
doughboy
got my 306gti6 ecu unlocked for 140 quid, dunno if the m3 is as easy though
zimmerbimmer1
- BMW Parts Meister
Sounds like your car has the ews system, check around the ignition barrel for the ring antenna if there is a plastic ring with a wire on it your car has ews.
To obtain a new key you would need to order it through your local BMW Dealer but you may have a problem ordering it as they WILL need to see the Reg Doc in your name with proof of ID..
If you do not have these it is down to the dealers discretion whether they would supply you a key or not
To confirm if your car has the ews system pm me the chassis number and I'll check it for you.
zimmerbimmer1
- BMW Parts Meister
The unfortunate thing is if the car does have ews and you can't obtain a key you will never start the car.
nickalauski
thanks for the advice.
there is a transponder reciever around the ignition barrel which is a problem! many others have done s50 engine coversions in e30's using standard management, so how is this possible?
will i need to get the ecu unlocked? if so who can do it?
- Homo Hair
no you install the ews into the e30!
eko
- Old timer
Can be started without the key even though it has EWS!
I havent done it myself but saw how it was done earlier this week
PM sent
PM sent
nickalauski
eko, top stuff.
i will try that tomorrow. fingers crossed!
eko
- Old timer
Let us know how you get on!
- Homo Hair
EKO mate, i dunno if that should be posted on the foum 4 all too see..
eko
- Old timer
Good point mate,edited nowJhonno wrote:EKO mate, i dunno if that should be posted on the foum 4 all too see..
ian332isport
Just out of interest, can you also PM me the info on how this is done ?eko wrote:Can be started without the key even though it has EWS!
I havent done it myself but saw how it was done earlier this week![]()
PM sent
Ian.
nickalauski
i will be trying to fire up the m3 today using methods discussed earlier.
i will report back later!
james_obryan
Pm me also (e36 here with broken barell)
nickalauski
still no luck in starting the engine. i also discovered a hole in the sump so i can not start the engine at this stage.
Also required is a 5 series m50 sump pan. if anyone has or knows of one please pm me.
james_obryan
I am breaking an S50B32 engine and have the sump, pm/email sent.
