What oil does everyone use - 325i's?
- Endless325
As above really, thinking of giving mine a service tomorrow!
Grade would be appreciated too
Cheers!
Edited to add the word oil - doh
Cheers!
Jesus325iTouring
- Frog freak !
Standard Comma semi synthetic,i'm too tight to buy any oil over £11.99.
That's good stuff!DanThe wrote:You think your tight,
I use 10w40 semi synth bought through Vauxhalls trade club which works out at approx £6 for 5 litres
I get most of my oil through Vauxhall motor factors. I've always put 10w40 in but I think the application books now suggest 10w30...
Dr Firefly
- E30 Zone Doctor
Same here - how much do you pay for 5l then? I get mine for £15 as the owner of the local carbits shop used to work down the pit with my dad, so I get things cheapgra325i wrote:i use castrol "high mileage" as it makes up for any wear in the block (apparently) not cheap tho
tylerma wrote: you oxymoron, you...
I've always used 10w40. Thinner stuff flows easier, but I'd worry about it being so thin it gets past the sealsold_skool_2002 wrote:That's good stuff!DanThe wrote:You think your tight,
Duckhams Q semi synth in mine
a very old mechanic put me onto it years ago as he said its well suited to older engines and its never let me down yet
www.oldskoolfantasy.co.uk
- Brianmoooore
Wear in the block!!! You got a Ford engine in your E30? Everything in a 200,000 mile M20 engine that I stripped once was still within new spec., and I expect this is typical of most BMW engines.gra325i wrote:i use castrol "high mileage" as it makes up for any wear in the block (apparently)
gra325i
- E30 Zone Meets/Events Team
dude calm down, im only quoteing what it says on the bottle im not for a minute saying that the bmr NEEDS it but its top quality stuff for my top quality motor..Brianmoooore wrote:Wear in the block!!! You got a Ford engine in your E30? Everything in a 200,000 mile M20 engine that I stripped once was still within new spec., and I expect this is typical of most BMW engines.gra325i wrote:i use castrol "high mileage" as it makes up for any wear in the block (apparently)
Firefly..i get mine from dingbro motor factors on a trade account £13.95 with my discount
Dr Firefly
- E30 Zone Doctor
gra325i wrote:dude calm down, im only quoteing what it says on the bottle im not for a minute saying that the bmr NEEDS it but its top quality stuff for my top quality motor..Brianmoooore wrote:Wear in the block!!! You got a Ford engine in your E30? Everything in a 200,000 mile M20 engine that I stripped once was still within new spec., and I expect this is typical of most BMW engines.gra325i wrote:i use castrol "high mileage" as it makes up for any wear in the block (apparently)![]()
dimebag_from_hell
does no-one here use a full synthetic oil?
Dr Firefly
- E30 Zone Doctor
I though the castrol magnatec and high mileage ones were full synthetic?
Same as Dan. Use the vauxhall trade club deals for oil. Used to use their semi synt(10w40) in my 325. Now put their fully synt in my s4. Its 5w30 I think, i know its not the best, but its an old engine, it doesn't need none of this £50 a tub oil
And at £13 odd quid(it might be less) you can't go wrong.
same heredazleeds wrote:Duckhams Q semi synth in mine
for sale one left kidney, high mileage, need slight bit of work, will p/x for front wings and rear qtr panelsbigun wrote:sell my sport i'd rather f**k the dog
- Brianmoooore
M20 can benefit from full synthetic oil, just like any other engine.
M20B25 on 240,000 + miles, running a full synthetic.
- orangecurry
yes, but I bet it ran on an ancient mineral oil for the first 200,000 miles - Brian I'm suprised at youBrianmoooore wrote:M20 can benefit from full synthetic oil, just like any other engine.
aus325
My 325 lives on a diet of Mobil 1 (synthetic 5w50). It had a tatty old yellow post-it note stuck in the service section of the owners manual "Mobil 1 only !" so that's what I've stuck with. Previous owner did oilchange every 5000km, and I've kept it up during my 3 years of ownership so far..
Magnatec 10/40 in mine since it was re-built 4500 miles ago, seems to be the most popular by the looks of it.
Semi seems the way to go, best of both worlds.
munky30
- 100% Pure Council
I have no idea what oil is in mine.
I asked for some oil for an 86 325 and the man in coopers gave me some.... didnt think to look what it was.
dimebag_from_hell
My dad uses a full synthetic on his aston martin, so its would just be handy for me to nick some of him
Plus my engine only has around 45 to 50,000 miles on it, so would it not benefit from a fully synthetic?
dimebag_from_hell
expensive?
Have a look >> http://www.opieoils.co.uk/dimebag_from_hell wrote:expensive?
march109
- Contact:
Fuchs Titan Supersyn 5w-40 with 9000 mile oil changes.
it depnends on how your engine is and what you use your 325i for?
i ran my old sport in sikolene pro s for 35,000miles and it ran better for it by the end
semi's and mineral oils brake down and allow engine wear when the car is driven hard on the road or track end of! where as a puckka fully sythetic oil with esters in it will stay as it should and protect when the oil temp gets high during hard usage. Even long motorway trips with the revs up for hours on end will get the oil really hot and cheap oils will start to breakdown and allow bottom end wear. It's a testiment to the M20's build quality that it will do the miles if it gets it's oil changed now and then with any old sh!t put in it. As alot of other engines won't put up with this treament!
the age of the M20 has nothing to do with it!
dimebag_from_hell
Is that "oilman's"' website?
