Auto Tranny(car does not move)
As the title states, I rebuilt my tranny with 69 miles on it (due to being in the gulf region) and just recently had the torque converter and valve body re-worked. After putting everything back together the car doesn't want to move. You can hear the gears shift when selecting D,R, 123, etc. but no movement. The fluid level is topped up as the mechanic says.. Any thoughts on this?
i got the same problem and still havent found an answer.
all i done to my car was change the engine and when putting the new engine back in i replace the seal on the gearbox for the torque converter but also have no drive
Black Sport
