Can anyone give me any advice on how to go about removing the internal A-pillar trim? I need to get in there to re-located the drain tube that runs down the A-pillar, as water is spewing all over my central locking control unit.
Alternatively, can anyone give any tips on how to re-locate the drain tube without removing the trim piece?
Cheers,
Dan
Removing internal A-pillar trim
cros
The trim clips out about 2 inches from the top of the pillar. You pull the TOP part away slightly (hold the bottom in), and lift up and out. An easy-to-break clip at the bottom and dash clamp are then released. That broken clip isn't too important
I remember having to unscrew the sunvisor bits to get the headlining to drop a bit too?
Having done all this, the drain pipe will still be hidden inside the box section of the pillar, visible through inch wide holes every so often.
Danstable
Bugger! Sounds a bit more involved than I was hoping! Do you think I stand any real chance of striking lucky and getting it back on by wiggling/pushing from the cavity behind the drivers side speaker?
