Electrical problems 316i F reg
herman
Sun Apr 01, 2007 10:59 am
Speedo does't work unless the radio is on, fuel gauge goes to full, and temp gauge keeps flicking to max red hot when it 'aint. Othewise it's a great car.
Any idea's
This is the last model with 1600cc injection.
herman
Sun Apr 01, 2007 3:18 pm
Any info................?
jcjdavis1
Sun Apr 01, 2007 5:31 pm
Hi Probs. might be due to batteries on SI board needing replaced.I had temp gauge that did same and changed SI board and prob. solved.Someone with more knowledge than me might have other ideas.
herman
Sun Apr 01, 2007 5:45 pm
Thanks whats a S1 board??
SI board could be responsible for some of the symptoms.
Check the earth connections on a stud above the glovebox (lots of brown wires).
No obvious connection between speedo and radio, so check the above first and report back!
herman
Sun Apr 01, 2007 5:48 pm
Is that in the car or in the engine bay?
SPADGE
Sun Apr 01, 2007 8:02 pm
herman wrote:Is that in the car or in the engine bay?
Behind the glove box inside the car.
herman
Sun Apr 01, 2007 8:36 pm
ok, faira nooshky Del
