PLEASE PLEASE, help me out here...
I'm from South Africa, will be doing a S50 transplant into my E30, and I really need your help, as I know there are manyof you that have done this before.
As far as I know there is no difference as to fitting a 3.0l or 3.2, they difference been the wiring!!
1. Would you advise fitting the 3.0l instead of the 3.2l? or would you say the power difference is huge, and fitting the 3.2l is a better option, even though the wiring can be difficult?
2. I've read that the 3.2l double vanos , is sometimes troublesome? your thoughts?
Guys, help on the above questiosn will be much apperciated, I know some of you have spend loads of cash etc, and found out the hard way, but please help me out if you can...
There are more questions I have on the actuall transplant, but I need to make up my mind as to which motor i want.
There there anything else I should consider when I make my final choice?
Rowen
