wheel bearing change
ric325i
Post Sat Feb 17, 2007 5:30 pm
ok so both side on the front need doing (as do a few other things) to be ready for the MOT.
failed first time :cry:
i have a decent idea on how to do it but right now my tool collection is practically none existent.
how the hell do you get the bearing out? do i need a set of pullers?
is it relatively a simple job? any advice would be great. :D
ajm-e30
Post Sat Feb 17, 2007 5:56 pm
the bearing comes complete with the hub mate, take the caliper off and the caliper hanger then undo disc bolt, pop the cap off the hub, undo the 32mm nut and it will come off with a bit of persuasion
ric325i
Post Sat Feb 17, 2007 5:59 pm
oh ok so it doesnt need no fancy tools? its just i did this with my 205gti and i was ready to through in the towel.
+i bet getting that 32mm nut will be a joy!
ajm-e30
Post Sat Feb 17, 2007 6:06 pm
it comes with the bearing kit mate, i might have the size wrong tho not sure, u will need a breaker bar and a sharp chisel to nock the nut edge over on the new one to mate, should take no longer than an hour each side, i think the caliper hanger bolts are 15mm and the allen key bolts in the caliper are 6 or 8mm
Ricksta
Post Sat Feb 17, 2007 6:17 pm
Its between a 35mm and 36mm socket! and its a pain to find one that big that also fits within the outer assembly!! did both mine 2 weeks ago, and had a real mission getting the socket, then it was too big to fit inside the hub! so we had to use a lathe to take off a skim round the outside of the socket!!
ric325i
Post Sat Feb 17, 2007 6:23 pm
Ricksta wrote:Its between a 35mm and 36mm socket! and its a pain to find one that big that also fits within the outer assembly!! did both mine 2 weeks ago, and had a real mission getting the socket, then it was too big to fit inside the hub! so we had to use a lathe to take off a skim round the outside of the socket!!
8O
drastic measures!
i have never bought a kit with the bearing i thought you just bought the bearing itself.
im sure its a easy job for a garage and since the old smoker is in for mot and track rod ends (i hate changing them a simply couldnt :cursin: )
i may just hand them the parts and say please do these too.?.
i hate passing a job over when i know can be done.
kam-325i
Post Sat Feb 17, 2007 7:13 pm
Its a 36mm socket. and yes, you may need to "thin" the side walls of the socket.
mac325i
Post Sun Feb 18, 2007 3:04 am
I did both front bearings today, they were easier than I imagined.
I bought a 36mm impact socket from halfords - perfect fit.
ric325i wrote: how the hell do you get the bearing out? do i need a set of pullers?
Once the caliper(13 &15mm), carrier(19mm), disk and hub nut are removed, simply bolt the wheel back on to the hub and use the wheel as leverage to pull the bearing from the stub axle.
hope this helps
ric325i
Post Sun Feb 18, 2007 3:27 pm
nice work! that is great information!
i have decided i can do it! if i get it back from its extreme welding! :cry:
thanx for the advice and nice pic mac :cool:
oze30
Post Tue Feb 20, 2007 8:09 pm
I just did mine this weekend. Got a 36mm Halfords impact socket (as above) and tried to do the whole wiggle the wheel for leverage, but gave up. Bought a bearing puller and had both sides done in about 30 mins.
I'd recoment that you get a puller and be done with it. My bearings were that far gone, that the inner race was almost welded onto the spindle shaft.
Not a bad job in total. 30 mins tops!
