idle
louis2035
Post Thu Feb 15, 2007 2:32 pm
afternoon guys
i decided to clean my throttle spindle, AFM and ICV today but now my the engine idles at about 1200rpm. whats the simpliest way to adjust it?
cheers
--alpina--
Post Thu Feb 15, 2007 9:54 pm
id say TB Air adjustment should sort it....
louis2035
Post Thu Feb 15, 2007 10:08 pm
how do i go about doing that?
Post Fri Feb 16, 2007 12:13 am
--alpina-- wrote:id say TB Air adjustment should sort it....
There is no idle speed adjustment on an E30. idle speed is controlled by the engine ECU via the ICV.
The butterfly stop on the throttle body is NOT an idle adjustment, and should not be moved.
Having said that, if some one's been at it before and opened it up so that now it's clean it passes enough air to raise the idle speed above normal, then nothing the ECU/ICV can do can bring it down.
Check the TPS is working correctly before you touch anything else.
