afternoon guys
i decided to clean my throttle spindle, AFM and ICV today but now my the engine idles at about 1200rpm. whats the simpliest way to adjust it?
cheers
idle
--alpina--
id say TB Air adjustment should sort it....
louis2035
how do i go about doing that?
There is no idle speed adjustment on an E30. idle speed is controlled by the engine ECU via the ICV.--alpina-- wrote:id say TB Air adjustment should sort it....
The butterfly stop on the throttle body is NOT an idle adjustment, and should not be moved.
Having said that, if some one's been at it before and opened it up so that now it's clean it passes enough air to raise the idle speed above normal, then nothing the ECU/ICV can do can bring it down.
Check the TPS is working correctly before you touch anything else.
