You need to go to the breakers and grab the connector blocks (including a decent length of cable behind them) that plug into the back of the swtiches... then splice in the exising cables from the feed to your originals...
Before you do this though... you need to slightly enlarge the existing holes in the centre console for the switch to fit. Be careful... too large and you're buggered! I'd advise getting one from a scrapper to play around with too.
There is actually a detailed write up of this mod somewhere on the internet...
Here in fact!
http://www.strictlyeta.net/technical/e36switches.html
Hope this helps...
Giles.
