rear pad warning lamp
gaszman
- E30 Zone Meets/Events Team
ive just got this damm light on all the time now . ok its not the wire checked that not dash re solderd the two joints on dash so do i just take the damm bulb out. shes a 320 i touring 1990
If the 220 ohm resistor has been resoldered, then there's a poor connection in the pad sensor loop. You have two sensors - front left and rear right. Either you have an open circuit pad sensor, a short to earth, or a bad connection in one of the plug/sockets where the pad sensors plug in.
If the pad sensor wires aren't dressed properly they will rub through on the inside of the wheel.
gaszman
thank you will check this out
