Cheers Truman
help with abs light
truman
Hi all. My neighbours e30 cab's battery died at the golf club. A new one was duly fitted and now the ABS warning light stays on. Does anyone know how to sort the problem out short of pulling the bulb.
Cheers Truman
Cheers Truman
215m3
There is a relay under the abs unit cover. It is the silver one that may cause a problem.
there is also a relay under the dash steering wheel side, it is twice the length of a standard relay.
other than that it could be a sensor or the ecu
Toby
1987 E30 M3 S14 Turbo
1971 V12 E type Roadster
It's either a coincidence, or he has the early ABS system with a voltage protection relay (?) mounted near the ABS ECU. This relay is easily damaged by attempts at jump starting or similar.
truman
Brianmoooore wrote:It's either a coincidence, or he has the early ABS system with a voltage protection relay (?) mounted near the ABS ECU. This relay is easily damaged by attempts at jump starting or similar.
Many thanks i'll take a look at them. TrumanIt's either a coincidence, or he has the early ABS system with a voltage protection relay (?) mounted near the ABS ECU. This relay is easily
