e30 m3 throttle body
oze30
Post Tue Feb 06, 2007 10:52 pm
Right
Just debating with a mate in oz that e30 m3 throttle bodies are the same if not very similar in bolt pattern to the M30 intake.
SO.. what i'm asking is this.
Does anyone have any pics of the mounting side of an m3 e30 throttle body.. and an m30b35 intake/head?
He doesnt think he can make them fit without a spacer/adapter.
Can anyone help?
Also what would be required if he did fit this to his m30 (btw its in a 735.. They're strange in oz!!)
Toby_Unna
Boost Junkie
Post Tue Feb 06, 2007 11:01 pm
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
it looks just like the S38 port shape and bolt pattern to me, as you'd expect. it's nothing like the m30.
you will very likely need an adaptor plate, unless you cut the ends of the TBs off and weld them to M30 manifold stubs. either way it will be a royal pain in the arse :D
oze30
Post Tue Feb 06, 2007 11:04 pm
Cheers toby
hmm.. would he be better off getting dcoe itbs?
ian332isport
Post Tue Feb 06, 2007 11:18 pm
He needs one of these:
http://www.bavariacars.com.au/products/ ... .php?id=32
Also happens to be in Oz 8)
oze30
Post Tue Feb 06, 2007 11:28 pm
He knows about that.. Just wondering which is going to be easier/cheaper to do
Toby_Unna
Boost Junkie
Post Wed Feb 07, 2007 9:04 am
m5 throttles ought to be cheaper
however that funky thing will definately be easier :D
Post Wed Feb 07, 2007 9:26 am
Toby_Unna wrote:http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
No idea whether it'll fit or not, but you can draw absolutely no conclusions from realoem or the ETK.
These diagrams are for identification purposes only, and may or may not bear any resemblance to the part they represent.
A part shown with a triangular 3 bolt flange may well have a four bolt rectangular flange, for example.
Toby_Unna
Boost Junkie
Post Wed Feb 07, 2007 9:46 am
i know what you mean Brian, but in my experience that relates to parts where the shape and design doesn't matter and one part may have been superseded by another of a different shape - e.g. an exhaust pipe joining flange.
in this case, the 12v and 24v port shapes are necessarily totally different.
oze30
Post Wed Feb 07, 2007 10:09 am
the e30 m3 ports look the same as the m30, just the mounting seems different.
Toby_Unna
Boost Junkie
Post Wed Feb 07, 2007 10:20 am
here you go
this is e34 m30 vs e28 s38 (which is actually upside down in the pic)
the 24v ports are quite a lot taller. mine have had the lower part filled in with weld before grinding back, and still needed a 20mm adaptor plate to get a smooth port shape. if i was starting from scratch again i'd seriously consider using bike TBs instead :D
oze30
Post Wed Feb 07, 2007 7:23 pm
Toby_Unna wrote:here you go
Is that the same for the s14 engine?
Toby_Unna
Boost Junkie
Post Thu Feb 08, 2007 10:12 am
I assume so. :D
