316 m10b18 fuel pump
e30mclow
the car is garaged for the week and I take it out at weekends, but for a long time now when I go to start it on the friday it kicks and then stops. The kick I'm presuming is the petrol thats already in the carb, but no more petrol seems to come up. I just pour a drop down the carb and it starts up fine and runs ok, same thing then the following friday. It's the fuel pump right? Its a weber carb not a pierburg
Check the filter isnt blocked
e30mclow
I did and it all looks ok, do the pumps give trouble? Ill have a closer look at the filter again and blow it out
Ive only known pumps to leak oil before, you could remove it and check for wear but it doesnt normally cause any problems.
Looking ok and being ok are 2 different things
Remove the filter from the line altogether and try it first, or replace with new
