316 m10b18 fuel pump
e30mclow
Post Wed Jan 31, 2007 10:39 am
the car is garaged for the week and I take it out at weekends, but for a long time now when I go to start it on the friday it kicks and then stops. The kick I'm presuming is the petrol thats already in the carb, but no more petrol seems to come up. I just pour a drop down the carb and it starts up fine and runs ok, same thing then the following friday. It's the fuel pump right? Its a weber carb not a pierburg
Post Wed Jan 31, 2007 11:20 am
Check the filter isnt blocked
e30mclow
Post Wed Jan 31, 2007 11:30 am
I did and it all looks ok, do the pumps give trouble? Ill have a closer look at the filter again and blow it out
Post Wed Jan 31, 2007 11:46 am
Ive only known pumps to leak oil before, you could remove it and check for wear but it doesnt normally cause any problems.
Looking ok and being ok are 2 different things :wink:
Remove the filter from the line altogether and try it first, or replace with new 8)
