I dnt want to be a forum twat, but i did a search and couldnt really find much, im sure theres loads on here, if someone can point me in the right direction, i would be greatfull.
I am considering buying this motorsport i have spotted but the mileage is very high, so i am considering throwing a m50 lump into it.
Just want to know how straight forward it is etc...
M50 into Motorsport
Jimbob
Sig link mate
e30_singh
You are trying to access a restricted area.
maxfield
An M50/2 engine (look for non-vanos engines with non-ews wiring loom(E34))
: Inlet manifold, throttle body and throttle cable from E34
: Modification to exhaust manifold - In the words of Brianmoooore: For the exhaust manifolds, I used a standard cast E36 rear manifold and a cast E36 front manifold with the section between where the three primaries meet and the flange removed and welded together.
Then, by chopping up the front pipes of an E36 system and a 325 E30 system and welding the bits together, I connected to the standard 325 E30 system just in front of the gearbox exhaust mount.
: Sump, oil pick up pipe and dipstick from E34 (Is it the same oil pump for E36 and E34?)
: E36 ally engine mount legs
: E34 M50 rubber engine mounts (or so I'm led to believe)
: E30 325i clutch and flywheel (6-7mm off of flywheel)
: E30 325i gearbox (custom gearbox mount/bracket, bend the selector rod 10-15 degrees!)
http://i11.photobucket.com/albums/a155/ ... G32336.jpg
: The above allows for an E30 325i propshaft, and a 3.64 diff at least (pref M3 diff)
: Mk2 golf brake servo with spacer between pushrod and master cylinder
: E30 325i everything else
parts list
parts list
Karan
hi mate
you need the engine/box, custom prop (£130ish), exhaust manifold work, brakke servo change,
thats a start
Karan
thats a start
Karan
Karan
wll my post was useless
Jimbob
It's not a restricted area, it's just a case of e30zone.co.uk or e30zone.net
Cheers to maxfield for pasting my link though.
Lol Karan, hey dude!
m-dtech
- Unapproved Trader caution
im doing an m50 install as we speak, i will post pics soon.
