Replacement Chip for ECU
Scotsman
Post Thu Jan 04, 2007 6:50 pm
Hi All,
I bought a Power Chip for my 318iS off Ebay. When I installed it the car started but idled rought at about 600rpm. I took the car for a run in order to allow the chip to 'learn' the settings. The car was really flat and unresponsive upto about 3000rpm where she took off. If I let the revs drop below 3000 she was unresponsive & flat again. I re-fitted the original chip and the car is back to normal.
I contacted the guy I bought the chip from and he reckons it could be to do with the knock sensors and the ignition over retarding.
Does this make sense? If so is there a way to fix this? or do any of you have any ideas what it could be?
I am going to replace the plugs at the weekend and try the chip again - the plugs haven't been changed for over 3 years.
Cheers.
Post Mon Jan 08, 2007 4:57 pm
IIRC, You're supposed to let the engine idle for 10 mins immediately after fitting a new chip (or even after any disconnection of the ECU/battery) in order to let it learn the basic idle settings, then go for a drive - during which it will feel initially lumpy and rough, even flatspotting (bogging down) at times, but after a while it should all smoothen out and enable you to extend up to the rev limit that the chip allows.
New spark plugs may well help too!
