Can anyone help i've adjusted the valve clearances but still seem to be hearing a tapping sort of sound which sounds like its coming from the top part of the engine i've also changed the manifold gasket. Any advice on what i can try next or if anyone else has experienced similar problems, will be appreciated.
Win
still Tapping
rmt
Search for threads about fuel injectors. I have read here on the zone that they can click loudly sounding like tappets. I think this is not really a problem other than the noise.
Rob
Rob
win
Cheers mate i think you could be right, i was just reading an old thread and one of the guys was mentioning about noisy injectors. Out of interest does this mean they are on there way out?
Win
Win
rmt
I'm not sure if it means they are on their way out or not.
wildeian
Single-point injectors 'click' when they open, it's quite common.
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
Not at all. It's the way they were designed. Modern engines use quieter injectors by design, and have the engines hidden under plastic covers to dampen the noise.win wrote:. Out of interest does this mean they are on there way out?
Win
