still Tapping
win
Post Sat Dec 30, 2006 2:07 pm
Can anyone help i've adjusted the valve clearances but still seem to be hearing a tapping sort of sound which sounds like its coming from the top part of the engine i've also changed the manifold gasket. Any advice on what i can try next or if anyone else has experienced similar problems, will be appreciated.
Win
rmt
Post Sat Dec 30, 2006 3:11 pm
Search for threads about fuel injectors. I have read here on the zone that they can click loudly sounding like tappets. I think this is not really a problem other than the noise.
Rob
win
Post Sat Dec 30, 2006 3:21 pm
Cheers mate i think you could be right, i was just reading an old thread and one of the guys was mentioning about noisy injectors. Out of interest does this mean they are on there way out?
Win
rmt
Post Sat Dec 30, 2006 3:51 pm
I'm not sure if it means they are on their way out or not.
wildeian
Post Sat Dec 30, 2006 3:58 pm
Single-point injectors 'click' when they open, it's quite common.
zaust
Zone day release
Post Sat Dec 30, 2006 6:07 pm
Is the noise getting to you when your driving the car..?
if so bottom of the steering coloum (engine side) rubber bung missing ?. The coulom is hollow and the sound travels through. answer :- block the hole..
M30 Tech 1 Touring on gas.
Post Sat Dec 30, 2006 8:47 pm
win wrote:. Out of interest does this mean they are on there way out?
Win
Not at all. It's the way they were designed. Modern engines use quieter injectors by design, and have the engines hidden under plastic covers to dampen the noise.
