exactly how do you preload the prop mount?
liam012
Post Sun Dec 24, 2006 5:57 pm
just wondering if anyone knows exactly how its done as i think i may have done it wrong
also a pic of a prop mount "facing the right direction" would be of great help.
i am troubleshooting a drive line shunt between gears and suspect the above as the culprit.
oze30
Post Mon Dec 25, 2006 12:42 am
to preload you slacken the bolts that hold the centre bearing, then slide it towards the front of the car about an inch (?) then tighten. I think the extended bit past the metal bracket points to the front.. though dont quote me on that
Post Mon Dec 25, 2006 10:25 am
I would limit the preload to about 5mm if I were you.
Should be done with the clamping sleeve nut slackened off and then tightened afterwards.
liam012
Post Mon Dec 25, 2006 10:34 am
thanks for that - i didnt slacken of the clamping sleeve when i did it,
still not sure if mine is facing the wrong way though, will have a gander - i presume threy would of made it obvious the correct direction to put it on and i have enough faith in myself to think i would of spotted it! so hopefuly no prop removal required this week!
Templ8e30
Post Mon Dec 25, 2006 5:55 pm
Iirc the mounting is offset to one side, if you have it the wrong way it won't sit in the transmission tunnel properly.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
