Any of you guys got any tips on what to do to the engine just before you start it for the first time after a major head rebuild.
Engine has been still for a good 3 months. I have been checking cylinder bores every weekend and coating block and bores with clean oil.
Cranking engine after rebuild....
kam-325i
Andy335Touring
Battery fully charged and conected up to a decent charger, drizzle some oil over the cam/rockers/etc, disconect the fuel pump relay and crank it over till the oil light goes out.
Reconect the relay and fingers crossed !
Andy335Touring
BTW remove excess oil from the bores before putting the head back on
kam-325i
The fuel system was killed when i stripped the engine, I shall clean the bores and block before the head goes back on.
I was worred about the cam and rocker.......
Andy335Touring
Turbo-Brown
- Boost Junkie
Cam should be coated in assembly lube.
Bores should be lightly oiled (and that'll protect them from rust forever pretty much)
Take the plugs out, isolate the ignition coil, isolate the injectors.
Crank the engine over until the oil pressure light goes out as the oil system will be empty. This will take an age to do!
Once you've established that the oil system's working, put the plugs back in, reconnect the injectors and ignition systems, cross everything and turn the key.
