Hi, I've got some old wheels in the garden that need a bit of TLC, was going to tidy up the scratchs with the dremel/filler what evers needed then paint/spray them black. What would you use to paint/spray them black? They don't have to be super quality finish so not getting them done properly, but would like something thats not going to flake off straight away?
Painting wheels
316eyes
Secret of any good paint finish is in the preparation.
Get the surface as flat as possible using progressive grades of wet & dry.
DEGREASE......important if you want the paint to stick.
Several light, even coats of a suitable primer, the better this is the better the final finish.
Flat with 1500 wet & dry.
DEGREASE again.
Several light, even coats of your chosen colour followed by laquer if required, according to the manufacturers recommendations.
Should get you a decent finish on a set of wheels.
Helps if you can find a local place that will shot/bead blast the wheels for you as this will save you hours of work, especially if your doing BBS or similar.
HTH
AND GOOD LUCK.
DEGREASE again.
HTH
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
cliffybabe
- Powered by Nelly
i'd use Hammeright
