torque settings
orr
does anyone know the torque settings for the crank sprocket on the e36 m3 3lt s50 ,the small alen key bolt that holds it in place.Do you also put thread lock on it. main bearing bolts also if poss. Is there a website were i can find all these thanks.
gcorky
- Boost Junkie
http://img201.imageshack.us/img201/7546/30m3fa3.png
link of image below.
ive just uploaded page for ya m8...hth.
[img][img]http://img201.imageshack.us/img201/7546/30m3fa3.png[/img][/img]
orr
Thanks gcorky but i cannot see the crankshaft sprocket on there ,or is it just called something else, were did you get that table
gcorky
- Boost Junkie
gcorky
- Boost Junkie
orr
Me again!
Should there be any up and down play in the gearbox input shaft on the E36 M3 box? Just unbolted mine from the engine and there seems to be a bit of play in it!
Orr
Orr
gcorky
- Boost Junkie
orr
There is a bit of old oil in there but not loads!
Orr
Orr
gcorky
- Boost Junkie
http://www.realoem.com/bmw/showparts.do ... g=23&fg=15
item 4 is easy enough to change..its the front seal behind guide tube.
is the spigot ok?
if it is id try a front seal as its cheap-n-easy....no worries.
is the spigot ok?
orr
Cheers for that ! I will check it out.
Orr
Orr
