Hi all
I had the boot lid open today and I noticed a lot of condensation on the underside of the bootlid.
Any idea why this would happen? Will it lead to rot somewhere eventually?
Condensation inside bootlid
Mahmood
Kos
it will attack your rear end !!
boot lid rubber, light seals, and aireal are all prime suspects
Mahmood
...Ooh Vicar, I hope not!!!it will attack your rear end !!
Seriously, thanks Kos. Ah ha...I know what it is...
I put some MHW rears on last week and I didn't get the right one on properly. Took them off today and there was some water in the right lense.
Put my original rear lenses back on today and will monitor over the next week.
Estoril-5
i have this also, so what is the solution?Kos wrote:it will attack your rear end !!
is there somekind of seal protector or something?
Kos
you need to play around with the brackets to get them on right ( well you do with the early spec ones which i belive you have)
change them back and see what happens, new gaskets from BMW are cheap though so might be worth investing in some
Mahmood
Spot on Kos.
I didn't fit the right bracket properly and could only get on nut on it. There's not much room to turn a spanner in there!
Anyway, back to factory spec. now.
Kos
you need to grind them back some times, thats what i had to do in the pastMahmood wrote:Spot on Kos.
any way, good luck
