Gearbox mount
johnl320
Post Sat Nov 04, 2006 5:34 pm
I need some help fellas with regards to what is going to hold the gearbox up in my conversion. Basically its an M30 lump using the E28 m535i dogleg gearbox. I need to know what two rubber mounts to use and what cross member as the ETK list quite a few variations. Has anyone else used the dogleg box????
Cheers in advance
john
johnl320
Post Fri Nov 10, 2006 10:24 pm
bump!
DRIFTBOY
Post Fri Nov 10, 2006 10:58 pm
My M30 engined E30 uses an E34 (not dog-leg) gearbox and I used the standard E30 325i gearbox cross member (bolted straight to the gearbox - no mods) with standard E34 gearbox mounting rubbers, although I think either rubbers will do.
If you haven't already had a look at the underside of the floor on your E30 you will see that the bolts the cross-member fixes to are in channels so can slide to the position you need! :D
I also used the E30 325i gear linkage to get the lever in the right place.
Hope that helps!
Demlotcrew
Post Sat Nov 11, 2006 9:16 am
You will need to use M3 crossmember and M3 bushes.
Just wait till you find out how much they are new.
Andrew
johnl320
Post Sat Nov 11, 2006 3:53 pm
Demlotcrew wrote:You will need to use M3 crossmember and M3 bushes.
Andrew
Yeah just found out, time for some fabrication me thinks :roll:
cheers mate
john
