Braided hydraulic clutch hose?
325zimmer
Post Sun Oct 15, 2006 8:10 pm
Does anyone know whether a Braided hydraulic clutch hose is available for a E30 325i and if so where can i get one from??
Pav
Turbo-Brown
Boost Junkie
Post Sun Oct 15, 2006 9:07 pm
You could probably make one up, although why would you want to?
When I replaced my clutch lines, I didn't wanna pay BMW the Ԛ£60 odd quid for the proper one so I made one up using the rear brake flexi hose from a 205 1.9 GTi, some copper brake line and the relevant M10x1 brake fittings.
Seems to work fine :)
Si316
Post Sun Oct 15, 2006 9:23 pm
A company called jaymic do one. Im not sure how much of an advantage it is but I did mine as it needed replacing.
IG: Si316ti
2.0L M10, Twin carbs, big cam
Full send restoration in progress
325zimmer
Post Tue Oct 17, 2006 1:02 pm
I found out that Goodridge do a replacement hydraulic clutch hose. So I've orded it via Rally Design Ԛ£20.60 posted. Not bad.
I will have to see what its like when it arrives, anyway its a lot cheeper than a BMW one!! :D
