Space behind dash
yz_250
Post Thu Oct 05, 2006 9:02 am
i have got a rev counter with shift light
but im not a fan on mounting it ontop of the dash
so the lazzy F@#$K i am i would just like to know
if some one knows how mush space it there
behind the dash (just under the radio in the little conpartment
just behind the ash tray)
dont need sizes just need to know if its alot or nuthing at all ?
Thx
Yz_250!!!!
"Sorry under the influence of driving in style"
orangecurry
Post Thu Oct 05, 2006 9:06 am
you'd probably manage... but if you are looking down there instead of straight ahead when driving fast, I'm glad you are on the roads in a country far far away....
Post Thu Oct 05, 2006 9:17 am
Plenty of room behind there ..... but, as Orangecurry says!
yz_250
Post Thu Oct 05, 2006 9:33 am
orangecurry wrote:you'd probably manage... but if you are looking down there instead of straight ahead when driving fast, I'm glad you are on the roads in a country far far away....
the shift light is very bright and il angle it so it shine in the coner of the eye ....
wount be looking down at 200km/h...lol
Post Thu Oct 05, 2006 9:34 am
Rewire the service LEDs on the cluster as a shift light.
yz_250
Post Thu Oct 05, 2006 9:49 am
Come to think of it ......thatâ┚¬Ã¢”ž¢s a f#$%ken good idea
Coz when the car switches on you still get your reading and when the car starts they go dead anyway
But you know what would be cool if you could actually wire them in a way that they go from green to yellow and then red when you have to shift?
Oiii !! Doz any one know how to wire that then??
*big round of Applause to Brianmoooore*
liam012
Post Thu Oct 05, 2006 9:56 am
ace idea brain
could it be done so they go from yellow to red? the electronics involved would be unfriendly though....
yz_250
Post Thu Oct 05, 2006 10:05 am
its easy to get then to go on when you need to shift you will just run a wire from the shift light to the LED lights but how to get the to run up would be a difficult task im sure of it !
but il open the shift light tonight and have a look ..
will keep you posted and might post a few pics of my discovery !
orangecurry
Post Thu Oct 05, 2006 10:17 am
yz_250 wrote: *big round of klap to Brianmoooore*
I couldn't have put it better myself winkeye
buster
Post Thu Oct 05, 2006 10:20 am
PMSL :teehee:
mrLEE30
Post Thu Oct 05, 2006 11:42 am
i doubt his wife/girlfriend/other half :? would be too happy with him having the klap
Post Thu Oct 05, 2006 8:02 pm
Principle of the circuit is simple enough. You'd need an ignition pulse to voltage converter - the electronics from a tacho with a two wire moving coil meter as a display. The voltage from this would need to be fed to something like a LM3194 LED bar graph driver.
This could be set up to light the first green light at, say 300RPM before the optimum change point, then light the rest of the greens, yellow and finally red as well as the optimum RPM is reached.
One for Smithy318i, after he's done the window modules!
yz_250
Post Fri Oct 06, 2006 7:31 am
Dammm ....do you ever not have a anser
you should be Brainmooooore .....lol
thx bud will give it a try !
