Post
Sun Oct 01, 2006 4:09 pm
Unless you have super smooth roads, don't go too low. The best suspension upgrade in my opinion is the MTEC setup. Get a set of used 318iS springs and the larger front suspension legs (51mm) and set of new Boge MTEC shocks. The drop will be small (~ 20mm) but you will notice a big improvement in ride.
If you want to go aftermarket, Eibach springs are good and Bilstein or Koni shocks are a popular chioce. Don't be tempted by cheap springs or suspension kits.
