Hi ,
will a 525e diff fitt into a 320 ok , assumsing i change the rear mounting plate?
can i use the 525 e drive shafts to ?? as 320 look to have smaller mounting flanges
525e diff into 320??
525e diff will fit into a 320 with a swap of the output shafts and the back cover from an E30 medium case (325) diff.
Why you would want to is another matter. If this is a standard 320, then you'll be lucky to get above third gear when driving it, all you'll be out accelerated by bicycles.
exup
- Boost Junkie
Thats Brian , i ve just fitted a complete 2.7 ETA lump in it an want to use it as a daily driver in london , so eta diff should do 30 mpg ( thats what my current e28 525e does in town )
will be fitting a 731 head next , once i ve re coned it , will the eta drive shafts fit e30 ??
That diff will still be a bit tall for your application, but will be livable with.
Never really studied 525e drive shafts, but I would expect them to be wrong length amnd wrong flange. 320 drive shafts will be OK if you get the output flanges from the same source as the rear cover.
