525e diff into 320??
exup
Boost Junkie
Post Fri Sep 22, 2006 8:42 am
Hi ,
will a 525e diff fitt into a 320 ok , assumsing i change the rear mounting plate?
can i use the 525 e drive shafts to ?? as 320 look to have smaller mounting flanges
Post Fri Sep 22, 2006 8:56 am
525e diff will fit into a 320 with a swap of the output shafts and the back cover from an E30 medium case (325) diff.
Why you would want to is another matter. If this is a standard 320, then you'll be lucky to get above third gear when driving it, all you'll be out accelerated by bicycles.
exup
Boost Junkie
Post Sat Sep 23, 2006 10:52 am
Thats Brian , i ve just fitted a complete 2.7 ETA lump in it an want to use it as a daily driver in london , so eta diff should do 30 mpg ( thats what my current e28 525e does in town )
will be fitting a 731 head next , once i ve re coned it , will the eta drive shafts fit e30 ??
Post Sat Sep 23, 2006 1:31 pm
That diff will still be a bit tall for your application, but will be livable with.
Never really studied 525e drive shafts, but I would expect them to be wrong length amnd wrong flange. 320 drive shafts will be OK if you get the output flanges from the same source as the rear cover.
exup
Boost Junkie
Post Sat Sep 23, 2006 1:49 pm
Many thanks as always Brain
