Diameter of pipes
Project_E30
Post Wed Sep 20, 2006 11:50 am
Can anyone tell me the external diameter of the pipes on item 4 below.
I want to remove the heating bit from the inlet manifold. And therefore put a joint in.
E30Mark
Post Wed Sep 20, 2006 1:47 pm
I think you actually want the internal diameter ! my guess is it's about 8mm...
PM for details
Project_E30
Post Wed Sep 20, 2006 3:11 pm
E30Mark wrote:I think you actually want the internal diameter ! my guess is it's about 8mm...
No the external diameter! As I need to know what size tube fits over it. Therefore the external diameter of the pipe will give me the internal diameter of the tube. :mad:
Gunni
Post Wed Sep 20, 2006 3:24 pm
you can also block that circuit from the source,
i.e put in a bolt in the hoses that are the correct size and thus stoping the circulation,
Or leave it, it has nothing do with performance only helping the throttle body from freezing in cold weather,
Gunni
@ 2012 VEMS group buy !!
