on the last m30 I did it had the hose coming from the back of the engine,
This one has it too so I was thinking IԚ´d use it the same way as the M20/M40 and all the other E30 engines have the coolant hoses routed??
M30 coolant ways
Gunni
Andy335Touring
Your using an early M30 then ? E23/24/28
I'm not sure on the M20/40 set up, sorry
I wonder if you can use the later E32/4 blanking cap to block it off ?
Gunni
But I can use this way
as I can use the pipe, this will make it just alike the M20 head and M10 and so on,
but how do you do it when you donԚ´t use this and use the later ones??
Andy335Touring
Like this with an M20 header tank and E34 top rad hose.
I just thought you would have a clearance issue with using that union
Gunni
Ahh, I just saw that in the other post,
and was going to post, it,
I might use that route as I already have 2 of those L shaped hoses,
is this used for what??
Andy335Touring
Oil catch tank for the crank case fumes, it's going soon as i'm going to plumb the fume pipe back in to the inlet
