M30 coolant ways
Gunni
Post Tue Sep 19, 2006 2:20 pm
on the last m30 I did it had the hose coming from the back of the engine,
This one has it too so I was thinking IԚ´d use it the same way as the M20/M40 and all the other E30 engines have the coolant hoses routed??
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Andy335Touring
Post Tue Sep 19, 2006 7:49 pm
Your using an early M30 then ? E23/24/28
I'm not sure on the M20/40 set up, sorry
I wonder if you can use the later E32/4 blanking cap to block it off ?
Gunni
Post Tue Sep 19, 2006 8:36 pm
But I can use this way :)
as I can use the pipe, this will make it just alike the M20 head and M10 and so on,
but how do you do it when you donԚ´t use this and use the later ones??
Gunni
Andy335Touring
Post Tue Sep 19, 2006 8:41 pm
Like this with an M20 header tank and E34 top rad hose.
I just thought you would have a clearance issue with using that union
Gunni
Post Tue Sep 19, 2006 8:46 pm
Ahh, I just saw that in the other post,
and was going to post, it,
I might use that route as I already have 2 of those L shaped hoses,
is this used for what??
Gunni
Andy335Touring
Post Tue Sep 19, 2006 8:50 pm
Oil catch tank for the crank case fumes, it's going soon as i'm going to plumb the fume pipe back in to the inlet
