High revving from cold
TaitRacing
Mon Sep 11, 2006 12:42 pm
Hello people
The '85 320i that I picked up on Saturday is revving too high from cold, but is fine from warm, is this a common fault on the m20? If so, what do I need to buy.
Thanks in advance
Adam
Globulator
Mon Sep 11, 2006 12:52 pm
No this is not a common fault!
Just check that the springs and cables are all strong/free enough to pull the throttle right back properly when cold.
Later on you may want to check for air leaks around the inlet system and also that the TPS - Throttle Position Switch under the butterfly is working OK and clicks off when you remove throttle when cold.
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
reory35
Mon Sep 25, 2006 11:31 am
hi guys, where is the throttle position switch? haynes maunal is getting on my nerves lol!
Love the life you live, live the life you love!
SGP
Wed Sep 27, 2006 2:02 am
It's right under the throttle body.
If it ain't broke..
Fix it till it is :)
