Replacing fuel lines
klu99apm
Mon Sep 11, 2006 11:05 am
My fuel lines under the car are very rusty and this was picked up on the last MOT. They're now leaking a bit near the fuel filter so its probably time to replace them, and some rubber hoses.
Where do I get new lines - I couldn't see anything on the GSF website so is the dealers the best place - does anyone know how much they'll cost and are they easy to fit?
Thanks!
FlappySocks
Mon Sep 11, 2006 11:33 am
Never done it, but its 8mm tubing. B&Q do copper pipe for about Ԛ£15 for 10 meters. I assume you will need to flare the ends out a bit to stop the hoses from slipping off.
E30Mark
Mon Sep 11, 2006 11:38 am
I'm sure the lines are only Ԛ£10 from the dealer, sod mucking about with the micro-bore from B&Q!
PM for details
eRgal
Mon Sep 11, 2006 7:23 pm
Fuel pipes need to be made of steel.
sorry
Mon Sep 11, 2006 7:28 pm
eRgal wrote:Fuel pipes need to be made of steel.
sorry
Blue plastic on the E36.
bigkev
Mon Sep 11, 2006 7:32 pm
almost all new cars are now plastic lines
Gwynleym10
Mon Sep 11, 2006 8:01 pm
could u put plastic ones on an e30, r e36 different route/that different?
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
smithy318i
Mon Sep 11, 2006 8:22 pm
sorry
Says who ?
Mine are copper.
klu99apm
Mon Sep 18, 2006 4:02 pm
Thanks for the replies.
The metal lines were only Ԛ£12.50 from the dealers.
The hoses are Ԛ£11 each but instead I bought some fuel injector pipe from Halfords and cut it to length - much cheaper.
The whole job took less than 2 hours, including a trip to Halfords!
dazleeds
old skool raver
old skool raver
Mon Sep 18, 2006 4:07 pm
anyone got any info on the plastic pipes???
could it be done to an e30??
stop the rot winkeye
www.oldskoolfantasy.co.uk
E30Mark
Mon Sep 18, 2006 4:41 pm
did the metal lines come straight, or rolled up?
PM for details
FlappySocks
Mon Sep 18, 2006 6:25 pm
Just out of interest, is there any reason why you can't just use rubber hoses to replace the metal lines?
bigkev
Mon Sep 18, 2006 6:30 pm
you can but they dont take a knock as well as steel e.g. speed bumps/road debris
especially if its lowered i would stick to steel and just get some underseal on them
klu99apm
Tue Sep 19, 2006 8:04 am
The fuel lines came 'pre shaped' so it was a simple job of just swapping them over (I think this is what you mean).
