Replacing fuel lines
klu99apm
My fuel lines under the car are very rusty and this was picked up on the last MOT. They're now leaking a bit near the fuel filter so its probably time to replace them, and some rubber hoses.
Where do I get new lines - I couldn't see anything on the GSF website so is the dealers the best place - does anyone know how much they'll cost and are they easy to fit?
Thanks!
Thanks!
FlappySocks
Never done it, but its 8mm tubing. B&Q do copper pipe for about Ԛ£15 for 10 meters. I assume you will need to flare the ends out a bit to stop the hoses from slipping off.
E30Mark
I'm sure the lines are only Ԛ£10 from the dealer, sod mucking about with the micro-bore from B&Q!
PM for details
PM for details
eRgal
Fuel pipes need to be made of steel.
sorry
sorry
Blue plastic on the E36.eRgal wrote:Fuel pipes need to be made of steel.
sorry
bigkev
Gwynleym10
could u put plastic ones on an e30, r e36 different route/that different?
smithy318i
Says who ?eRgal wrote:Fuel pipes need to be made of steel.
sorry
Mine are copper.
klu99apm
Thanks for the replies.
The metal lines were only Ԛ£12.50 from the dealers.
The hoses are Ԛ£11 each but instead I bought some fuel injector pipe from Halfords and cut it to length - much cheaper.
The whole job took less than 2 hours, including a trip to Halfords!
dazleeds
- old skool raver
anyone got any info on the plastic pipes???
could it be done to an e30??
stop the rot
stop the rot
www.oldskoolfantasy.co.uk
E30Mark
did the metal lines come straight, or rolled up?
PM for details
PM for details
FlappySocks
Just out of interest, is there any reason why you can't just use rubber hoses to replace the metal lines?
bigkev
klu99apm
The fuel lines came 'pre shaped' so it was a simple job of just swapping them over (I think this is what you mean).
Motronic to Megasquirt Plug and Play Guide
