Im currently collecting parts for an m20 turbo, with a target of 300bhp (flywheel). The car will be used for trackdays and i want minimal lag.
Found this turbo, for the people in the know will this be ok in regards to target power and minimum lag.
Garrett T04 Turbo
Compressor A/R 60
Turbine A/R 96
Many thanks dave
Turbo ok?
Ant
- Retired Team Member
with that big a turbine housing she will spool late in the rpm range dudeGarrett T04 Turbo
Compressor A/R 60
Turbine A/R 96
for your needs, 0.67 A/R turbine, 0.50 ish A/R compressor in 60mm trim should be spot on, thats a cosworth T3 to you and me BTW
HTH
Email FTW
oldroydsr4
Too laggy then i guess, what sort of power would this be good for, if the other components were up to it.
cheers dude
cheers dude
fuzzy
i use a t34 which i believe has .63 and .48 housings and that kicks in nice and low at around 1400 rpm and will handle up to 28 psi and 380 bhp.£765 brand new
Turbo-Brown
- Boost Junkie
Crikey, if you're spooling at 1400rpm on a 2.0 litre, that'd be ideal for a 2.5 aiming for no lag!
