indicator signal cabin noise
placey
Post Wed Aug 09, 2006 9:33 pm
does anyone know which component makes the turn indicator ticking noise inside the cabin please? and would this be straight forward to swap for a ford unit? i've always found the ticking noise to be too loud and harsh. the same noise in my scrote van is much more refined....
paul
i saw a doctor and she gave me some pills....
smithy318i
Post Wed Aug 09, 2006 9:36 pm
the relay is mounted under the steering boss.
you can easilly muffle the noise by adding foam to the inside of the lower cover.
fuzzy
He who sleeps with "Gingers"
Post Wed Aug 09, 2006 9:41 pm
or by turning your stereo up,thats what i do when i hear an odd noise :mad:
TheRealest
Post Wed Aug 09, 2006 9:46 pm
i like fuzzy's option
placey
Post Wed Aug 09, 2006 9:56 pm
cheers smithy - by 'under the steering boss' do you mean the lower of the two panels that shround the steering column and the igintion key barrel?
fuzzy - the stereo in mine sometimes gets turned up.... but sometimes the missus is a passenger.
paul
fuzzy
Post Wed Aug 09, 2006 9:58 pm
i find that if my missus is in the car the stereo is up loud anyway to drown out the nagging winkeye
smithy318i
Post Wed Aug 09, 2006 10:00 pm
placey wrote:cheers smithy - by 'under the steering boss' do you mean the lower of the two panels that shround the steering column and the igintion key barrel?
paul
yes.
the relay on the lower left.
placey
Post Wed Aug 09, 2006 10:05 pm
cor blimey that was quick! you must have had that picture all ready lined up... so it's the grey one yes? (i'll probably be able to hear/feel it working when i get the panel off) and i won't have any issues if i wrap it about heat build up or anything else sinister will i?
paul
