convertable roof problem
tonym3
Post Mon Aug 07, 2006 10:42 pm
my friend has a problem with his electric roof could anyone tell me how to put it down manualy also i am looking for a new rear window.tony
stevieg
Post Mon Aug 07, 2006 10:56 pm
The electric hood on mine uses two motors,one to operate the hood and one to operate the deck lid,these can be disengaged using a release mechanism located at the side of each motor,if you stick you head in the boot and have a look at the bulkhead at the rear of the seats you will see some cut outs,the release arms look like tubing,stick a rod or screwdriver into the tube and pull sideways,this releases the mechanism,pull the other way and it will click back and re-engage.
Rosc0PColtrane
Post Tue Aug 08, 2006 4:43 pm
Electric hood wrongness. Manual hoods are just so much faster
DaveD
E30Zone Wiki Specialist
Post Tue Aug 08, 2006 4:53 pm
well that was helpfull!
stevetigger
Post Tue Aug 08, 2006 5:49 pm
blatantarrogance wrote:Electric hood wrongness. Manual hoods are just so much faster
Yer right, Takes me 30 seconds to lower it!
Manual= Getting out the car :mad:
robmpulse
Post Tue Aug 08, 2006 5:54 pm
I wish the power top on my 1993 E30 worked. When I hit the switch, I can hear a motor running. Have no clue which one it is or why it was disconnected.......
I would assume one of the two motors are bad. However, I have also heard of a bearring goind bad that isn't too hard to replace.
I manually operate it and have been since I got it. I have a 1990 also...and it's manual.....so already used to it.....
I have just heard a lot of horrow stories of repairs costing better than a grand.........and it's just not worth that to fix it for me.....
DaveD
Post Tue Aug 08, 2006 11:40 pm
if you pm me an email address i will forward a few links that might help
