Sump Removal, engine in (m20)?
320Touring
Mon Jul 31, 2006 11:10 am
How difficult is it to remove the sump with the lump still in the car?
after my "discussion" with a traffic island, the sump no longer holds oil..
I reckon i'll need to loosen the mounts and jack the lump up..where is the best place to jack it?
thanks
neil
eamo
Mon Jul 31, 2006 11:41 am
far easier if you attach the engine to an engine crane and then drop the subframe
320Touring
Mon Jul 31, 2006 11:49 am
eamo wrote:far easier if you attach the engine to an engine crane and then drop the subframe
I dont have an engine crane to hand unfortunately! will splash out if required
Templ8e30
Mon Jul 31, 2006 3:03 pm
Much easier with a crane, you'll need to lift it a good 4-5 inches to get the sump past the oil pump.
I did this a few months ago when the gasket started to leak, took about 2 hours with a crane.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
tomson
Mon Jul 31, 2006 3:05 pm
Ive done it before by removing the two nuts over the rubber engine mounts, removing the viscous fan then jack on the gearbox (using a piece of wood to protect the box) as close to the lump as you can.
This gives you enough room to remove the oil pump bolts and bobs your uncle etc!
hth
Tom
Brian28
Mon Jul 31, 2006 7:22 pm
We did it but had workshop ramps and airguns, dropped the front crossmember and left the engine in place, about 20 mins with two of us working on it flat out. (Was the night before Bands and we had a last minute problem with a leaking gasket). A good couple of hours on the driveway tho without proper kit I reckon. Good luck.
stonesie
Mon Jul 31, 2006 9:15 pm
I would use 1 of these if i had to do my sump gasket (again :roll: )
http://www.pvrdirect.co.uk/productInfo. ... tRef=53094
slideways
Mon Jul 31, 2006 10:58 pm
you dont actually need to drop the sub frame. i took out the bolts on th p/s and just loosened the ones on the d/s. jacked up the engine til it touched the bulk head and out it came.
prob be a good idea to fit a sump gaurd or re inforce the sump when u is fixing it
320Touring
Wed Aug 02, 2006 11:45 am
could I use the sump off of a eta lump?as I have one available? or is it a different shape?
Templ8e30
Wed Aug 02, 2006 2:44 pm
320Touring wrote:could I use the sump off of a eta lump?as I have one available? or is it a different shape?
525e sump ? if so it might just fit but is a different shape to the e30 m20 sump and you'll lose the oil level sensor if you have it.
Cheers,
Iain T
e30bmlover
Ac Schnitzer prophet
Wed Aug 02, 2006 4:01 pm
320Touring wrote: after my "discussion" with a traffic island, the sump no longer holds oil..
i love how people describe things lol
