can a faulty CPS cause no spark?
ollielsd
as in title really. can a failing CrankPositionSEnsor cause an intermittant no spark problem??
Ant
- Retired Team Member
yes it can.
No Posistion/rpm signal, no sparky, no fuel
its commonplace for the wiring to rub through behind the waterpump pulley dude, worth a poke with a torch
to test the sensor, there should be 550 ohms between the middle and one outer pin iirc.
Email FTW
ollielsd
cheers ant, got another sensor on route thru a mate so will throw is and se what happens!
