Snaped a rocker! Has this happend to anybody else?
beadle
Post Thu Jul 20, 2006 9:04 pm
Driving down the road and -BANG! Then got a clunking sound and no power!
So i take it 2 my mechanic mate , He takes the rocker cover off and sees the snaped rocker! So we get a new rocker, take the rod out the front of the car ,with the fan and the rad and replace it! Then put it back together??? But Car is F**ked ,Ive got no power and the idle is up and down!
Well pissed off!!!!!!! :-x
Anyone had this happen? Or no what 2 do????? :(
It goes like a metro!!! :cry:
Steviec
Post Thu Jul 20, 2006 9:34 pm
Sounds like you need a better mechanic! (joke!)
Ive snapped a rocker before but I also replaced the rocker shaft and end caps while it was out. I didnt have any problems after though.
Has everything been put together properly and no wires knocked loose?
Might be worth checking the cable and plug on the AFM and also check all the plugs leads and distributor cap, make sure nothings loose. Also were the leads put back in the right order? Just checking.
Oh, what engine is it?
Andy325i
Post Thu Jul 20, 2006 9:41 pm
as above, also valve clearences or bent valve?
Andy
Post Thu Jul 20, 2006 9:46 pm
rockers can break on cars with valve clearances too tight which are driven hard.
It's a head off job aswell so i'm told. They do wear so i would think replacing them all could be a benefit. I think they are £10 each though!
U can get the cam out without taking the head off but it's a bonnet off job and undoing the engine mounts and jacking it up
hth
oh and don't drive it!!!
Jerran
Post Thu Jul 20, 2006 9:51 pm
Happened to me a few years ago in my M Tech 1 Sport, was having fun in it one day, pulled up to a set of lights and noticed it was running on 5. I think number one had snapped. Engine still ran though obviously didn't sound right running on 5. Head came off, replaced more than just the broken one and had change from £200. Car was fine after that.
beadle
Post Thu Jul 20, 2006 9:56 pm
Nice one for all the replyz! And its a 320i by the way, The engine was rebuilt at christmas!! :cry: The head was not!!!!!! Taken off :cry: F**k it new rebuild-or 325 in it.............
beadle
Post Thu Jul 20, 2006 9:58 pm
Jerran wrote:Happened to me a few years ago in my M Tech 1 Sport, was having fun in it one day, pulled up to a set of lights and noticed it was running on 5. I think number one had snapped. Engine still ran though obviously didn't sound right running on 5. Head came off, replaced more than just the broken one and had change from £200. Car was fine after that.
Change from £200? Yeah? Shit my so called mate wanted£150 for just changeing the rocker????.......... :-x
e21Jason
Post Thu Jul 20, 2006 10:12 pm
Hi
As part of my 3.0l I got some billet steel rockers made up as I have heard the were a weak stop around 7k, micro polished for more power.
Jason
Turbo-Brown
Boost Junkie
Post Thu Jul 20, 2006 10:14 pm
Would imagine Jerran did the work himself for that price TBH.
It's a pretty labour intesive job, especially with the engine in the car!
Steviec
Post Thu Jul 20, 2006 10:35 pm
My mechanic just opened the bonnet, jacked the engine up, removed the grill and got the rocker shaft out their!
My mechanic is in Harlow, Essex and he doesnt charge much. I can give you his number if its any use (oh he rebuilds top fuel dragster engines for his team over weekends, so I know his works good!).
beadle
Post Thu Jul 20, 2006 10:43 pm
Steviec wrote:My mechanic just opened the bonnet, jacked the engine up, removed the grill and got the rocker shaft out their!
Yes steve! Nice one ! Thats pretty much what my mate did , but he said he loosened the head bolts and got it out like that!!! :? Yeah i know , he has probably mashed up the head gasket? But he seemed to think it was ok?
Andy335Touring
Post Thu Jul 20, 2006 10:52 pm
Do a compression test as my money is on a bent valve
beadle
Post Thu Jul 20, 2006 11:07 pm
Andy335Touring wrote:Do a compression test as my money is on a bent valve
Will do andy , nice one!
Image :cry: :cry:
Post Fri Jul 21, 2006 12:08 am
Post Fri Jul 21, 2006 12:25 am
Brianmoooore wrote:
+1
fit a 325i..
Quaser
Post Fri Jul 21, 2006 12:43 am
i'd also say got for a 325
fowler
Boost Junkie
Post Fri Jul 21, 2006 4:49 am
has to be 2.5 so this 2.0ltr rubbish :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
