How can you tell the if a head is a real Alpina M20 B3 2.7 Head? Are there any numbers or identification to look out for?
I've seen a head for sale at the wreckers who claim its an Alpina head but it may just be a worked head.
Alpina M20 2.7 Head Verification
kidsinister
reggid
only 4 digits?kidsinister wrote:If it's genuine Alpina, it will have four digits stamped into it near the front, inlet side. Simple as.
Thanks for your help
Demlotcrew
Later cars have Five.kidsinister wrote:If it's genuine Alpina, it will have four digits stamped into it near the front, inlet side. Simple as.
The numbers are just above to the right of the thermostat housing, vertically stamped on a raised part of the head.
Andrew
reggid
then it look promisingDemlotcrew wrote:Later cars have Five.kidsinister wrote:If it's genuine Alpina, it will have four digits stamped into it near the front, inlet side. Simple as.
Andrew
Cheers guys you've been a great help
valves should be bigger too, i'm not sure how big standard 2.5 valves are to help!
Can i have it? i need one! big please
reggid
i think the valves are bigger than 323i etc but same as 325i 42mm/38mm but i am not sure of this yet.Simon13 wrote:valves should be bigger too, i'm not sure how big standard 2.5 valves are to help!
