I recently changed out the crossmember on my 320 cab and now I appear to have disturbed the rack as it leaks from the top of the pinion where the steering column / couplings fit in. ive been told there is a seal under the plastic dust cover on the top of the pinion that can be replaced.
question is:- is this true and can I just get a new seal from the stealers or will they just tell me its a sealed unit and a new rack will cost a gazzillion bucks.
p.s. nothing leaked before I replaced the crossmember.
why is it that you fix one thing and it causes another to fail?
