The vacuum line on my Fuel pressure regulator has split at the regulator end. It's bodged up with some tape at the moment, but obviously needs replacing.
Can I buy the pipe as a part (sorry realoem blocked at work)? Or will I need to make one?
Vacuum line split at Fuel pressure regulator
Ant
- Retired Team Member
you can buy the part but any vacuum hosing from your local factors is fine dude
Email FTW
SD
Cool - thanks
